Idle screw maxed out. How do i lower idle?
Old Sep 17, 2012 | 10:36 AM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
i have an early 90's roller motor L98. Stock long block. .480 lift cam, HEI distributor, plugs gaped to .045. Shorty headers with a 3in catback exhaust custon ypipe. AIR SMOG AC delete
The intake manifold is a holley street dominator with an open plenum. 1 inch carb spacer. and a holley aluminum avenger 670 vacuum secondary carb with the 4 corner metering block adjutment. brand new carb.
The idle screw is maxed out when lowering the idle. ive been advancing my timing which has caused me to have to lower the idle. Any help?
Old Sep 17, 2012 | 01:22 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: Idle screw maxed out. How do i lower idle?
First, make sure the throttle cable isn't holding it open. Next, you may need to adjust the secondary idle screw. Not sure where it is on the Avenger series, but on the older Holleys you have to take the carb off and flip it over to see the secondary screw. If neither of these helps, then you may have a vacuum leak and a carb that was running a little too rich. This would make it act like the throttle is open more than it actually is.
What is the timing set at?
Old Sep 17, 2012 | 04:42 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
actually i just lowered the fast idle and that seemed to help. it allowed me to lower the curb idle to what i needed
Old Sep 17, 2012 | 10:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Advancing the timing has the effect of upping the idle speed. You must mean retarding the timing....?
Old Sep 18, 2012 | 10:16 AM
JaBoT's Avatar
If your fast idle screw is engaged when the engine is warm then you choke is not properly adjusted or the wires are not hooked up. That is why the fast idle is on.
You need to adjust and or hook up the wires on the choke, not turn the fast idle screw.
Old Sep 18, 2012 | 09:58 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Correct. You shouldn't really be making these adjustments when the engine is cold, and when the engine is warm enough to be adjusted, fast idle should be completely off.
The OP was correct. Every engine I have ever worked on, advancing the timing increases the idle speed. Engine idle speed is simply the equilibrium point where internal friction within the engine matches the power output of the engine. This is why idle drops when you put the car in drive. You just added a lot more friction/load to the same amount of engine power. As you advance timing at idle, combustion becomes more complete, resulting in the engine producing more power with the same amount of air and fuel input. As engine power goes up, idle speed increases until increased friction within the engine balances the increased power. As you retard timing, you reach a point where combustion becomes so poor that the engine ceases to make enough power to overcome its own friction. It lugs up, stalls, and dies. It gets a lot more complicated than that when you look at increased cylinder pressures and temperatures with timing advance, but it all in effect lends to the engine making more power and speeding up.
Old Sep 18, 2012 | 10:51 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
yes advancing the timing did bring the idle up, thats why i had to lower it back down with the curb idle screw. In case i wasnt clear
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
camaro71633
Sep 1, 2015 10:24 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
