Fuel pump shutting off?
Car: 84 trans am
Engine: 355
Transmission: 700r
Ok I have carbed 350 with a edelbrock performer and with a external electric fuel pump ran by a toggle switch and the pumps gas but once the car is running it stops pumping? Im confused what would cause this?? I bought the car about a month ago and it ran fine until yesterday.. Any ideas?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Fuel pump shutting off?
What year, make and model is your car?
Has the pump stopped running altogether or only when the car turns on? Do you have a regulator? What kind of pump is it? Is the return line still hooked up?
92camaroJoe
Aug 13, 2015 06:07 AM
