running with the key off
Old Oct 24, 2012 | 01:24 PM
system155's Avatar
Car: 89 camaro iroc, 89 camaro rs
Engine: 350-iroc / 305 rs
Transmission: 700r4 / t5
ok so i did a swap my tbi to a carb and when i turn off the key it still runs for a min. im using the tbi fuel pump and i have a pressure reg up front and i was wondering for whom done this how did u stop the built up pressure so ur car stop running when u turn the key off
Old Oct 24, 2012 | 01:42 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: running with the key off
Do you have a return line?
What is the timing set at? What carb? Is the carb setup properly?
Old Oct 24, 2012 | 01:49 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Sounds like dieseling which can be too much timing, too rich idle mixture, too hot temp range spark plugs. etc.
Try leaving the car in drive when you shut the engine off. This usually will make it quit but you need to check your timing and tune the carb first.
Old Oct 25, 2012 | 09:24 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Agreed with bestracing, sounds like dieseling. I had the same issue when i did my swap and it was timing related.
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
Jae992
Aug 27, 2015 09:07 AM
