Fuel Pressure regulator question.
Anybody used a Professional Products 10653 Powerflow Fuel Pressure Regulator 3 Port Clear on a TBI to Carb swap ?
http://www.streetsideauto.com/p/prof...buretor-10653/
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Fuel Pressure regulator question.
Not I, but it looks like a nice one. If you end up getting that one you could give it a thumbs up or down. Welcome to the forum.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
We used this on my brothers 82Z http://www.summitracing.com/parts/MAA-4309/ Works like it says.
Car: 1989 SS
Good deal ,at the time i don't believe my brother paid 100$ at summit, i think it was more around 80$ at the time or some sort of summer deal they had going on.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
So, the 4309, properly connected & adjusted on our cars, should be able to have 5-7 lbs at the carb with existing factory 5/16" return line.
Would it be accurate to say, everybody here with a TBI to carb/4309 swap does not have any issues with excessive carb-side fuel pressure, unless there is a restricted return downstream of the regulator?
Engine: Broke - 350
On rare occasion the regulator could have a pressure creep problem.
Engine: 305 TBI
Axle/Gears: 3:08
Yes I would agree that if you are getting excessive fuel pressure to the carb then you are restricted down stream. More than likely the short section of rubber hose near the tank is either swollen inwards or kinked. If it has never been replaced you should just replace it due to age anyway. It's a cheap and easy fix.
Engine: Broke - 350
9192camaro
16
Feb 3, 2019 12:21 AM
