To what RPMs do i set my Q-JET to idle at..?
Old Nov 1, 2012 | 10:03 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I advanced my timing and my idle went up, usually my car has been idling at 1500RPMs (yes i know its high) but what would you guys recommend I set it too..?thanks! my engine is an LG4
Old Nov 2, 2012 | 07:02 AM
Re: To what RPMs do i set my Q-JET to idle at..?
Roughly what the sticker says; if memory serves, something around 700 out of gear, 600ish in gear.
Don't trust the trim package in your dash for that, they're usually wrong, specifically by reading WAY higher than reality. Sometimes as much as twice or even 3 times what the actual engine RPM is.
Old Nov 2, 2012 | 12:56 PM
Damon's Avatar
When it first fires up overnight-cold it's SUPPOSED to idle higher- it's built into the choke linkage. But when the engine gets driven around and warms up some it should drop back down to a normal idle speed, called "curb idle." And I think Sofa is right about the curb idle RPM spec and not trusting the factory tach.
Old Nov 2, 2012 | 01:53 PM
calgutie's Avatar
Car: 1984 Z28
ohhh ok and how do I adjust the idleing n my carb...I knwo theres a little screw on the sdide by where the accelerator linkage is at but my idle is still high....I dont see and vacum leacks and ive plugged up my hoses that are open.........
Old Nov 2, 2012 | 08:56 PM
Damon's Avatar
Is the choke getting fully open when the engine is warmed up? If not, it's going to hang onto the last step of the "fast idle cam" built into the choke linkage and never drop down to curb idle fully, especially when the weather gets cooler.
Most common reason is that the choke heater wire simply got knocked off the terminal on the choke element (round black thing on the pass. side of the carb with a single wire electrical terminal built into it).
Old Nov 14, 2012 | 05:41 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Have you verified there are no vacuum leakes?
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
