Holley Carb Identification
Car: 1984 Chevrolet Camaro z28
Engine: 383 sbc
Axle/Gears: Stock...this is next
Hi Guys,
Hoping someone here might be able to tell me what rebuild kit I need for my carb. I've inherited a 750cfm Holley with no choke horn, so I can't identify it by the part number. The carb has dual metering blocks, dual inlet, no choke, vacuum secondaries and is square bore. From the reading i've done, it appears to be a 4150 style. I don't have much experience with holley carbs, and I know that there are 10,000 different rebuild kits. Hoping I can get some help. The only numbers I can find on the carb are on the metering blocks, both say 33101. Thanks very much for your help guys
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Holley Carb Identification
http://www.summitracing.com/parts/hly-37-1539/overview/
then click on application.
click on r3310-1.
click on r3310-1.
Engine: 383 sbc
that was very helpful, thank you very much. If i'd only known it was so easy, I wouldnt have bothered anyone! Thanks Joe
sreZ28
Oct 22, 2015 08:21 AM
1984, body, carb, carbs, carburetor, carburetors, choke, f23, holley, horn, id, identification, identify, identifying, numbers
