Setting Fast Idle at Cold or Operating Temp
Old Nov 20, 2012 | 07:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What's the best bet, a cold or a warm engine (I've read that the latter will provide a false reading)?
JamesC
Old Nov 20, 2012 | 09:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
With a completely stock engine, setting it warm is a safe bet.
With a modified engine, might as well set it cold so you get what works well.
Old Nov 20, 2012 | 05:36 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Setting Fast Idle at Cold or Operating Temp
Mine is set up for the cold weather right now. I figured when things warm up I'll switch back to operating temperature.
Old Nov 21, 2012 | 08:04 AM
Damon's Avatar
Fast idle setting only matter when the choke is on, which means the engine is cold when it operates.
Guess which way I'm leaning on this issue?
I set it so it's in the ballpark and then tweak the setting a little each time I do an overnight-cold start. Couple days of that and you'll zero in on where it feels comfortable.
Old Nov 21, 2012 | 08:35 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, It's two seperate adjustments.
Let's assume we are only talking about cold fast idle. In order to set it, idle mixture, idle speed and A/C stepper (if equipped) must be dialled in perfectly while engine is warm. Make sure your choke heater, whichever method your engine is using, is working properly.
Next, when the engine is cold, you have to adjust both the angle of the choke valve and fast idle at the same time. And when I say cold, I mean overnight, not just down to where the temp guage is all the way to the left. Then over the course of the next few cold mornings, you can fine tune your fast idle to whereever you are happy with it.
Old Nov 24, 2012 | 11:20 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hmm, mine was set 2800 when the carb was rebuilt. All I did was dial down the screw adjustment on near the choke to pull the fast idle down to around 2200. Kicker is currently set to about 1400, something I still need to dial back down.
I want to bring the fast idle down farther, 1800 or so, but I'm afraid I'll just stall out. I know on cold mornings if I start the car and kick down from high idle to the second idle which is currently 1800rpm or so, the car stalls out.
specialized
Jun 18, 2022 09:26 AM
Fast355
Dec 2, 2016 06:33 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
