Rough idle and stalling
Old Nov 26, 2012 | 12:51 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
Car was running fin up until the other day when it was a hard time starting, and then a very rough idle, almost felt like it was misfiring or like 3 fires in a row and then a pause and it repeats. I was also noticing some smoke as well, it looked blueish but didn't smell like oil. It stalled on me a few times at stops and I spent 40 min at a gas station trying to get it to start up. When it stalls and I go to start it up it smells like I poured gas all around my car. I did a fuel system cleaner to see if it would help and did a quick seafoam in the carb, not sure which did it, but one of them made the problems go away for about 10 miles and then the rough ridding started up again. I saw that it most likely is the rings leaking oil into the piston, if this were a stock motor I could see that, but not on a 2 year old engine.
Old Nov 26, 2012 | 01:05 PM
Dinmiller's Avatar
Car: 86 Camaro IROC-Z
Transmission: 5-speed man
Re: Rough idle and stalling
Check the timing on your car. Mine was doing that yesterday until I got it adjusted right.
Old Nov 26, 2012 | 02:17 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
It's always good to check your timing first. After that with you saying that it smells like you are dumping gas out I'd remove the air cleaner and check the carb to see if you have a stuck float and have gas coming out of the bowl vent into the carb. Something is causing the car to flood out when you shut it off and that is the first thing to check. Also see if anything else is leaking fuel that shouldn't be.
If you are dumping a lot of fuel into the motor I'd get that fixed right away. Too much fuel getting dumped into the motor can cause the cylinder walls to get washed down with fuel and cause premature ring wear and possible compression problems
Old Nov 27, 2012 | 01:58 AM
Dabesiv's Avatar
thanks for the help guys, Im taking it to the shop tomorrow, this is over my head haha. hopefully its nothing major.
jklein337
Sep 19, 2018 06:23 PM
greenyone
Sep 2, 2015 03:39 PM
IROCtometal
Sep 2, 2015 02:01 PM
JHX
Aug 29, 2015 02:30 PM
