What is this? (from airbox) Where can I find a replacement?
Old Dec 15, 2012 | 04:14 PM
Stalker7d7's Avatar
Car: '83 Camaro Berlinetta
Engine: 2.8L v6 (LC1)
Transmission: A3
http://imgur.com/TBHIE (large image)
This is/was a tube going from..something...to my airbox (passenger side). And the tube part of it ell apart, completely (disentegraded really).
First, what is it, and what does it do? Also, what are the side effects of not having it on?
Second, I can't find a replacement for it anywhere, nor can I even find out what the heck it is...
Third, can I just tape up the holes and attach it to a rubber hose to fix it?
Thanks for your help in advance!
Old Dec 15, 2012 | 08:11 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: What is this? (from airbox) Where can I find a replacement?
Looks like a grommet for the PCV fresh air supply. It lets clean, filtered air into the crank case to replace the dirty air being sucked out by the PCV. You should find a way to hook it up. Even if you can't find the proper piece, you should be able to cobble one together so it will function.
specialized
Jun 18, 2022 09:26 AM
gta90
Sep 15, 2015 04:00 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
