84 Camaro z28
Car: 1984 Camaro Z28
Transmission: Automatic
84 Camaro z28
hello yall hows it going, I have a question about my 84 z28 im new to working on cars and trying to learn as much as i can cause i love cars,but anyway, why do I Constantly gotta keep pressing on the accelerator pedal for the car to start? is it my started going bad?
Car: 1984 Z28
Engine: 355
Axle/Gears: 3.73 LS
Re: 84 Camaro z28
Hey! that could be a few different things, start with the basics! make sure the plugs and plug wires are good, carb or TPI is in tune, but it very well could be the starter. my advice would be better safe then sorry! changing a starter motor can be done with a lift or by any shop. its relatively cheap compared to getting a tow! if and when you do change the starter get a gear reduction model, they are smaller and sit back farther from the headers keeping them cooler prolonging the life of it
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: 84 Camaro z28
Having to give it gas to get the car to start is nothing related to the starter..Is it a carbed motor with a mechanical fuel pump?
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: 84 Camaro z28
my 84 z28 did the same thing, try pumping the pedal to the floor quickly three times then starting it, should fire right up. its normal for a carb'd engine to do that, even the best tuned carb will always start hard, especially in cold weather or at night. if it still has the q-jet check the plugs regularly to make sure they aren't black, from what i gather running rich is a cc q-jet problem
Re: 84 Camaro z28
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: 84 Camaro z28
my old quadrajet was so out of wack and shot that i had to shove a screwdriver down the choke each time i tried starting it. how i miss the pain of starting that old thing
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
Re: 84 Camaro z28
I love starting my T/A because of this. Later this year I'll be explaing the differences between that and a modern FI car to my daughter as she gets closer to getting her permit. When I turn the key in the FI car I feel like I'm missing out on something.
Transmission: 5spd
Re: 84 Camaro z28
i just wish i could take the time and spend the money to really rebuild mine correctly. i have factory service manuals on them thanks to ebay, and a dwell meter, and a multimeter, and a set of the smallest drill bits screwdrivers and Allen wrenches needed lol
CarGuyDennis
137
Dec 6, 2016 11:02 PM
GVMV
Aug 16, 2015 08:01 PM
