Rebuilt carb wont run now.
Old Mar 5, 2013 | 11:49 AM
Mike Cox's Avatar
I have a 84 camaro, It was running before I took off the carb, I rebuilt it and pt it back on and it didnt run so i went and bought a carb off a running truck and it still wont fire, i have fuel air and spark. I have a new hei distributor in it and a new ignition moduler. Everything is on time, spark wires are on the right points, im confused why it wont start, timing can't be an issue because it was in time before the carb change. i also tried pouring gas down the carb and still no pops just starter turning it over and i can hear its compression strokes
PLEASE HELP!!
Old Mar 5, 2013 | 11:58 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: Rebuilt carb wont run now.
Was the new distributor in prior to the rebuild or did you do it at the same time?
Old Mar 5, 2013 | 12:01 PM
Mike Cox's Avatar
The distributor was before the carb rebuild everything was running before i took the carb off Im at complete confusion at why the new carb wouldn't run it came off a running engine
Old Mar 5, 2013 | 01:09 PM
ChrisC's Avatar
What kind of carb? Can you see fuel getting to the carb?
Old Mar 5, 2013 | 01:17 PM
Mike Cox's Avatar
Yep i can see fuel going in and i tried pouring some in too and still no fire, its a quadra-junk
Old Mar 5, 2013 | 01:23 PM
ChrisC's Avatar
Is it computer controlled? Are you sure you had approprite spark when you tested?
Old Mar 5, 2013 | 01:34 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Pull the plugs and look at them. If they're gunked up black, clean them off and try again with just a little bit of fuel poured down the carb, maybe a couple teaspoons. With no choke on and no throttle see if it will fire.
midge54
Dec 27, 2019 04:14 PM
pimp2303
Jul 27, 2017 02:03 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
