Removing in-tank pump when converting to carb ?'s
Old Apr 1, 2013 | 09:50 PM
717camaroz's Avatar
ok so i have an 88 camaro and am also doing the tbi to carb swap.. can i pull the electric fuel pump and strainer out and just put a inline fuel filter in before the mechanical pump like on the frame somewhere and then the class one after the pump by the carb? and what do i do with the evap line to the canister?!?!
Old Apr 2, 2013 | 08:13 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: Removing in-tank pump when converting to carb ?'s
here's a link to convert your EFI pick-up to carb pick-up.
https://www.thirdgen.org/forums/carb...nk-pickup.html
If you are using a mechanical pump do not put the filter in before the pump. You just need one filter after the fuel pump and be careful of the type of filter you use. Some of the cheap clear filters use to cause more problems and didn't work very well. Just keep the filter away from heat sources when mounting.
Old Apr 2, 2013 | 08:31 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
You could also use a fuel pressure regulator (return style) to regulate fuel pressure to 5psi. That way you won't have to drop the tank to remove the pump. Compared to dropping the tank this says it all (way easier). I use Mallory 4309 regulator and I love it.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
