91RS V-6 to 5.7 carb how to hook up the stock gauge
Old Apr 10, 2013 | 01:03 AM
Reborn91RALLY's Avatar
Engine: 5.7 carb
Transmission: TH350
I have a 91 RS, which had the 3.1L. I pull the engine and installed a 350 Carb. Can use the original engine harness for the gauges, I also have a ignition box. I know i have to install a v8 cluster 145mph which i want.
Old Apr 13, 2013 | 04:24 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: 91RS V-6 to 5.7 carb how to hook up the stock gauge
hook up WHICH stock gauge?
Old Apr 14, 2013 | 10:07 PM
Engine: 5.7 carb
Transmission: TH350
Well i plan on installing a dash cluster with the 145 mph. Now the question is can i use the v6 harness going to the fire wall.
Old Apr 15, 2013 | 12:29 AM
greggbruce's Avatar
not sure -- you would have to check the paths of the printed circuit on the new cluster to see if the wire that hooks to that terminal leads to the same gauge as on the old cluster....
Old Apr 15, 2013 | 12:47 AM
Engine: 5.7 carb
Transmission: TH350
I'see. I hate wire's. now if i remove the cluster and cut out the plastic part of the dash. How hard will it be to get to the firewall and install mechanial gauges. You think that will be easier? Since you mentioned the circuits, which was design for V6 car. I don't want to tear the whole dash apart.
Old Apr 15, 2013 | 01:06 AM
greggbruce's Avatar
personally, I would rather make the new cluster with the electronic gauges work, it will be a much cleaner look and it is possible. Mechanical gauges tacked on somewhere around the dash just look a little ghetto to me..... just my 2 cents.
Old Apr 15, 2013 | 01:09 AM
Engine: 5.7 carb
Transmission: TH350
I guess that would work to
Old Apr 15, 2013 | 08:48 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
The engine side wire harness will have the same connections for V8 or V6 for things like oil pressure, temp, Alt ect. The color codes for the wires also remain the same. Since you are swapping to a V8 gauge cluster you will have solved the problem with the tach. I would think the connectors should be the same but it would be good to check. All color codes for wires are the same for V6 and V8 cars so that makes it a little easier.
Old Apr 15, 2013 | 04:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure about the later Camaros, but the early ones ('82-'89?) had the same circuits for all of the gauges, regardless of V6, V8, carb, EFI, etc. (except the digital dash Berlinettas).
I'm not as familiar with the later Camaros. Did they have a 145 MPH speedo? I thought that was only the earlier ones.
Old Apr 15, 2013 | 11:41 PM
Engine: 5.7 carb
Transmission: TH350
thanks
Old Apr 15, 2013 | 11:42 PM
Engine: 5.7 carb
Transmission: TH350
the 90's had the 145mph. i told they are rare.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Dec 27, 2019 04:14 PM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 7, 2015 04:49 AM
