3/4" Carb spacer worth the Install?
Old Apr 21, 2013 | 01:11 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Alright so yesterday I was at the junkyard and picked up a 3/4" spacer for only $6 so I was what like Wat the heck why not. Im thinking of installing it on my cc-q-jet, I have a cowl hood so clearance inst much of an issue apart from it looking taller which is kinda what I want to go for the look, will it see any gains performance wise?
Old Apr 21, 2013 | 03:59 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: 3/4" Carb spacer worth the Install?
maybe, maybe not... what kind of a spacer? if it's a 4 hole, then you might see a slight torque increase due to the better signal to the venturis, if it's an open spacer and you have an otherwise stock engine with stock exhaust, you might actually kill torque and power due to the extra plenum volume killing the signal to the venturis..
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 7, 2015 04:49 AM
