fuel pump
Old Apr 27, 2013 | 06:07 PM
leezickmund's Avatar
Car: 92 Camaro RS
Engine: 305 Tbi
fuel pump
Ok...at this point ive got the entire passenger side harness out of my car. Doing a carbd l69 swap from a monte carlo ss using an edelbrock 650 and cam, ect. What im trying to find is a thread that shows in detail possibly, or explains what ineed to do in detail to maintain the intank pump with a regulator. Pleaseeee help. Car is a 92 rs 305/t5
Old Apr 27, 2013 | 06:37 PM
Car: 92 Camaro RS
Engine: 305 Tbi
Re: fuel pump
Ive searched for awhile and nothing really gives me the details im needing...
Old Apr 28, 2013 | 10:20 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: fuel pump
In detail ?
Install the original pump line to a return style regulator then the regulator return to the original return then hook the carb up, There's no reason to fool with the factory pump wiring that I know of.
Adjust the regulator to carb pressure specs and hit the road.....
Old Apr 28, 2013 | 03:57 PM
Car: 92 Camaro RS
Engine: 305 Tbi
Re: fuel pump
With the harness removed and ecu not connected it will just turn on with the key on?
Old Apr 28, 2013 | 03:58 PM
Car: 92 Camaro RS
Engine: 305 Tbi
Re: fuel pump
I understand the fpr, thats not an issue
Old Apr 28, 2013 | 07:57 PM
Restrorob's Avatar
Car: 88 GTA
Re: fuel pump
Sorry, Can't help with deleting the ECU and wiring, When I installed the 502 crate in my GMC, All I did is remove the harness loom and trimmed out all the injector and sensor wires I didn't need then re-loomed. Plan on doing the same on my GTA carb engine install.....
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
