Holley Fuel Pump
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Holley Fuel Pump
I have a Holley fuel pump an the an fittings are in the way does anyone know how to rotate the pump an will anything jump out of it? Thanks.
Re: Holley Fuel Pump
Holley's used a few different designs over the years. The latest is their brand name on the Carter pump. If that's the one you've got you take out the 6 screws, clock the bottom casting to a different set of holes and put the screws back in. Yes, there is a spring in there that can fall out but that's about it. It's not one of those "million little pieces" type of situations.
9192camaro
16
Feb 3, 2019 12:21 AM
Dialed_In
Aug 20, 2015 01:45 PM
