Fuel Filter
Old May 17, 2013 | 02:45 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Fuel Filter
On my 87 iroc changed it over to carb. mech. pump in the block can I use the stock filter in the same location or do I need one by the pump? coming out or going in to the carb. Thanks.
Old May 17, 2013 | 05:17 PM
Fueled's Avatar
Car: 08 G8 GT, 98 Z28, 86 IROC, 85 Z28
Re: Fuel Filter
Did you keep the in-tank pump or did you already remove it? You can use the in tank pump with a return style regulator. No need for a mechanical pump.
If you use a filter with a mechanical pump, most mfg suggest putting it after the pump. You want as little resistance as possible on the sucking side for proper flow. I've personally ran a fuel filter before the mechanical pump without any ill side affects though.
Old May 17, 2013 | 05:24 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Fuel Filter
i still have the stock filter, and one right before the carb, after the regulater.
i ditched the in-tank pump and fabbed a pick-up for the mechanical pump..
but yea, a return style regulater will work if your keeping the electric pump.
Old May 17, 2013 | 10:19 PM
cscampbell92's Avatar
Re: Fuel Filter
Sometimes people will recommend not to sometimes they will recommend it. A filter before a mech. Will decrease the chance of pump failure by clogging, but add a little more of a load to it's sucking ability.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
