305 to 350 swap CC quadrajet carb too little?
Old Jun 9, 2013 | 09:09 PM
warmachine's Avatar
I put a pretty much stock 350 into my 84 firebird. it has headers and a weiand intake. I'm running the stock CCC out of the 305. While it seems to run fairly well. I'm afraid i'm running lean. What do i need to do to make it run better with the 350? I read about a chip but i'm not sure what they even look like or where they are. Any help would be appreciated!
Old Jun 10, 2013 | 05:39 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 305 to 350 swap CC quadrajet carb too little?
Don't worry about a "chip" on a carbed car they are pretty worthless. Not worth the money you'd spend on it.
the 305 Qjet on a "stock" 350 should run just fine, the Qjets are fairly large carbs and unless you're running a cam with performance heads and headers, the stock Qjet should be fine. You can always tune it. You'd need a wide-band 02 sensor though to do it properly. You will also need a dwell meter and...some small jewelers flathead screwdrivers. However, if the Qjet was running fine on the 305, it won't lose it's adjustment on the 350.
theshackle
Mar 5, 2017 06:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
