Bypass CPU with carb and replace q jet
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Bypass CPU with carb and replace q jet
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
take a look at the " Welcome to the Carburetor Forum; Please Read." sticky in this section
Car: 87 Z/28
Engine: 5.0L
Axle/Gears: 9 Bolt posi
When I swapped my Qjet out for a 650 Edelbrock (qjet was toast), I also took out a lot of the EGR crap to clean out the bay a bit (I don't have emissions where I am) I disconnected everything from the Qjet. installed the new manifold and carb (also swapped out the dist. for a new one) and it fired right up. Only issue i had was the gauge fuse blowing on me, I ended up disconecting all the pigtails for the EGR system and now the car runs amazingly. Made just a smidge over 140HP,160ft/lbs to the wheels. and that's on a 26 year old motor, with 200,000kms on it. Can't wait to rebuild it and do some more bolt-ons!
if you have any issues, I'm up in camp right now, but I'm home next week and I'd be more than willing to see exactly what I had to disconnect and let you know
I just replaced mine not too long ago. Didn't need a new distributor it's just a normal vacuum advance dist.
I have a demon 650 and I already have an aftermarket manifold so I guess I should put a distributor?
beachrodder
Aug 25, 2015 08:05 AM
