Pinesol as carb dip works awesome!! - PICS INSIDE!
Old Oct 18, 2013 | 12:36 AM
Kyle86's Avatar
Car: 86 Camaro IROC-Z28
Engine: 4.8 LS 68mm turbo
Transmission: Turbo 350
Axle/Gears: 3.08 10 bolt
I read on a motorcycle forum that some people use pine-sol to clean their carbs. With berrymans chem dip now costing $30 for 1 gal, I got the same amount of pinesol for just $8. I soaked the carburetors in pine sol topped off with water overnight and then brushed over with a toothbrush. Then I rinsed them off with the hose, dunked in some diesel fuel to keep the corosion off, drained for a bit then wiped clean with a rag.
CARB 1 - BEFORE
Carb 1 - AFTER
CARB 2 - BEFORE
CARB 2 - AFTER
Old Oct 18, 2013 | 07:38 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Pinesol as carb dip works awesome!! - PICS INSIDE!
Yup I have done it a few times. Old trick I have used on may motorcycles.
BTW berrymans is about $15 at walmart.
The look good, now take them apart.
Old Oct 18, 2013 | 08:04 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you are able to keep the plastic stuff on with the pinesol? that dip eats it. looks like you found those in a pile of dirt or something, lol but did an amazing job though cleaning it. might use this trick on my atv, but there is a bunch of plastic on it that is a pain to put back together
Old Oct 18, 2013 | 08:26 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
This is something I will try. Did you soak them overnight?
Old Oct 19, 2013 | 01:48 AM
Kyle86's Avatar
Yes, soaked for about 15 hours total. I didn't even really have to brush them at all. When I pulled them out in the morning they were already clean like that for the most part.
OH AND THIS IS SAFE ON RUBBER DIAPHRAMS AND PLASTIC PARTS!. I soaked a motorcycle carb for somebody earlier today and it came out fine!
DISCLAMER! THIS DOES APPEAR TO AGGRESSIVELY REMOVE THE FINISH IF THERE IS ONE. Not a problem in my case as they were already goofed but it does appear to remove a dichromite zinc finish.
Old Oct 19, 2013 | 11:47 AM
Damon's Avatar
I wouldn't worry about the finish, Kyle. Regular carb-dip can take it off, too. Usually it's mostly gone before you dip it, you just can't see that it's gone with all the gunk and crud on top of it.
BTW- I like your front float adjustment gasket. Might want to replace that with the proper one.
Old Oct 19, 2013 | 09:11 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I have seen my dad use this trick too back in the day. Man it really made my mom mad when she went to clean the floors and all the pinesol was gone lol!
Old Jun 22, 2014 | 09:21 PM
ricksmorris80's Avatar
Dilluted or straight?
Old Jun 24, 2014 | 11:29 PM
Kyle86's Avatar
either, i tried both and straight works fastest but diluted works too
Old Jun 25, 2014 | 04:52 AM
Cool thanks
Old Jul 5, 2014 | 12:18 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Wow that is one oooold 600. Script on the float bowls was from way back. Just gave away 4 or 5 of those.
Now throw some carb kits on them and hit ebay!
409 is another real good cleaner
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
mustangman65_79
Aug 11, 2015 03:17 PM
the_nikfive
Aug 11, 2015 02:46 AM
