Rebuild quadrajet
Rebuild quadrajet
Hi everyone!
I have a 1984 Trans Am all stock LG4 Engine 305.
My carb is bad. I don´t have time to rebuild it. I´m not from usa so shipping is quite expensive.
I want to buy a rebuild one. I need a bolt on and drive carb.
I can only set the idle screws.
In my country nobody knows about ccc quadrajets.
Can you tell me a good rebuilder where i can buy a rebuild one?
What do you think about ebay?
Also my second question: I must make a new fuel line from pump to carb.
I know its a 3/8 line but with what fittings on the end?
Is this 3/8???
Hope you can help me in that.
Is this 3/8???
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Rebuild quadrajet
Hi everyone!
Is this 3/8???
Is this 3/8???
Car: 1984 Trans Am
Hi everyone!
Is this 3/8???
Is this 3/8???
You can also buy from Jet Performance http://www.jetchip.com/jet_carburetors.asp
You can also contact Robin Grey at "AutoPontiac" in London, he can rebuild or get one there that might be easier on shipping. AutoPontiac
Transmission: 5-Speed Manual
Cliff Ruggles at Cliffs High Performance rebuilt my carb. I sent mine to him, but he also sells them. I would highly recommend him to anyone. Great work.
Thanks for your help. I also heard cliff is the best. I only thought he rebuild your own carb. so i must pay 2 shippings. If he sells complet quadrajet that´s it.
what is your mpg rating on your 84 trans am?
did cliff get your 84 q-jet?
thanks
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If the shops don't have one I suppose you could find someone on here parting out the same year as you have and have the carb and line shipped to the re-builder and then shipped to you. One thing to look out for is if the throttle bore is worn out, and the shop should mention that. Another common issue is that the fuel inlet can erode over time. It can be quite expensive to have a CC Quad built and an after market might be worth checking into. I know of a local place as well that used to rebuild for the dealerships but I doubt they have an exact match sitting around.
Car: 1984 Trans Am
Before I swapped to the 355, I was getting 22-24mpg with my old 305.
After the engine swap, I'm getting 19mpg on the highway at 70mph (115kph- ish) and 12 mpg in town (no highway).
3.8TransAM
Sep 27, 2015 08:37 PM
