Engine wants to quit after warm up
Old Nov 18, 2013 | 09:18 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Don't know where the proper forum for this issue would be, so I threw it in the "Carb" section
After the car is completely warmed up (engine temp gauge goes to and exceeds 220...the fan turns on, the engine temp does not redline ) and I am idling at a stop, when I start to move it takes a lot (A LOT) of gas pedal to keep the engine from quitting. I almost have to fudge the modulation between the clutch and gas to keep the engine from stalling.
The car runs flawless when cold. The plugs have been changed.
Here are some issues that I think may point to something.
1) exhaust manifold leak... Ticking sound and exhaust smell from the front of the car. Could the extremely hot exhaust air make vapor lock an issue?
2) Passenger side spark plugs (2-4-6-8) all have excessive carbon (oil leak in the cylinder head?)
3) rebuilt carburetor installed 18 months ago.
Anyway, I hope I provided enough info
Chuck
Old Nov 19, 2013 | 09:03 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Engine wants to quit after warm up
Chuck
1. Get headers! Hooker 2055 or Dyno Don's! Easier to work around and will free up 10-20hp. It's not vapor lock.
2. Possibly. Do a compression check.
Finally, take a look at this tuning part for the Qjet here: Quadrajet Tuning
Hope this helps!
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
