fuel pressure gauge
Old Dec 24, 2013 | 04:07 PM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
fuel pressure gauge
just bought a 670 holley street avenger have a tbi 350 coverted to carb. im using a tbi fuel pump. and i have the mallory fuel pressure regulator 4309. im needing a fuel gauge. im not sure which one to use. any help?
Old Dec 24, 2013 | 07:47 PM
Damon's Avatar
Re: fuel pressure gauge
Just don't use a liquid-filled gague. They can be as flaky as a bowl of Raisin Bran. Half of them don't read right out of the box. The other half get flaky within a couple years.
Old Dec 24, 2013 | 09:23 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You'd also need an isolator if a liquid (mechanical) gauge is going to be installed inside. I've never had a problem with mechanical gauges though.
As far as I know there are two levels as far as pressure goes, and with a carb you would want the lower pressure version with the pickup/sensor installed between the regulator and the carb. IIRC 6-7 lbs of fuel pressure so I think the gauge would go up to 10-15 psi instead of 80-100 psi.
Old Dec 29, 2013 | 11:21 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
autometer liquid filled gauge, 4 years now, no probs yet
Old Dec 29, 2013 | 12:38 PM
here is the gauge i am looking at. http://www.jegs.com/i/JEGS-Performan...ductId=1231913
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
