tpi to carb distributor question
Car: 1988 irocz
ive got a msd distributor, 6al box, and blaster coil....my question is will this set up work once i switch over to carb or will i have to get the old style hei distributor
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tpi to carb distributor question
You need a vacuum advance distributor not a computer controlled one.
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
I don't see why it wouldn't work. I'm running the msd 6al ignition box, blaster 2 coil and a msd distributor.
Car: 1988 irocz
I guess I should clarify I'm currently using the msd distributor for the tpi.... will it work for the carb as well using the same wiring and such...just wanna make sure I have all my "t's" crossed and "i's" dotted before I start this lil project
Engine: Lb9
Transmission: M20
You need a non computer controlled distributor to control advance and retard the timing. If you leave in the tpi distributor your timing will never change from the base setting.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
