carb. eliminate ECM
Old Feb 15, 2014 | 04:46 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
carb. eliminate ECM
I got a 92 camaro that has been carb'd for awhile now and wanting to clean up engine bay. Can I eliminate the computer and still have all my guages work ? Not sure if any of the guages or a/c run through the computer. If not then I will dissect the harness to and cut all the extra wires out.
Old Feb 18, 2014 | 01:18 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: carb. eliminate ECM
If you take out your computer you're going to have to swap out your distributor too. A/C is not run through the computer (I don't think at least). You can always get a mechanical set of gauges off an older model and not worry about it.
Old Feb 18, 2014 | 03:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You shouldn't have to cut any wires.
The gauges don't go through the computer.
Old Feb 18, 2014 | 08:04 PM
Car: 92 camaro RS
I disectee the harnes and I dont need the computer at all everything goes from the sensors to the guages direct. I did keep the wires for the speed sensor. I got rid of the auto and cut those wires out and all other wkres are gone. Motor is carbd so I didnt need dist. Wires you just need a power and a tach wire. Left those in there and left all a/c wipers and wores that I jeed. But everything is gone and looks good now just gotta tape everything up and put new looms on it.
Old Feb 18, 2014 | 11:25 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Did you have any problems with your fuel guage? When I purchased mine it was carbed aswell and my fuel guage has never worked....
Old Feb 19, 2014 | 07:41 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Fuel gauge has nothing to do with the ECM. More than likely you have a bad sending unit or something wrong with the wire connections going through the tank.
You will have a connector above the axle. The grey wire is the power to the fuel pump, black with white stripe will be ground, and purple (I believe that's the color) is the sending unit. If there is something wrong with the sending unit then the ohm meter will read an open across those two wires. If you connect an ohm meter across the purple and black wires you and get a resistance measurement then your problem might be either the gauge in the dash or the wiring to the gauge.
Old Feb 20, 2014 | 05:58 PM
Lmancha96's Avatar
Engine: LB9|TPI
thanks for all the info ill look into all of this when I get a chance.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
