Switching from TPI to Carb - '88 IROC
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
So I'm starting to build a 383 stroker and completely replacing the engine (I have a 305 TPI). I have a few questions (yes, I searched, just confirming).
All of my factory gauges will still work with the ECM gone, yes?
Also, I'm planning a T-56 swap (goal is 500-ish HP, so the T-5 will surely grenade if I keep it), what's the easiest way to keep my factory speedometer and make sure it's accurate? I also plan on switching to 4.11 gears in the differential.
Preferred fuel pump workaround?
And what's the preferable way to wire the fans in?
Car: 1983 Z28
Engine: 385 Fastburn
Re: Switching from TPI to Carb - '88 IROC
Is this a track only car? 4.11's will have your screaming going down the road. (even more than 3.73's for that matter).
If your car has the mechanical speedo this link will help:
https://www.thirdgen.org/forums/tran...-how-hook.html
Car: 1983 Z28
No insight on fan wiring, I run a mechanical.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I had a 69 Z28 with 4:11s and it turned about 3500 RPM at 65mph. I could almost watch the fuel gage needle move to empty.
Engine: 350sbc
Transmission: TH700R4
I did the sawp to a89 GTA last summer.and just wired a switch to the fans.
And as for a fuel pump I took a file line and brought it to the passenger side and used a mechanical pump.
And I removed all wiring from the ecu harness and the gauges still work.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Use a fan switch that screws into one of he cylinder heads. Summit sells the for around $40+shipping. Wire the radiator fan relay's ground wire the the switch. I did that after initially using a rocker switch to control the fan and it works great.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Why do you want to ditch the TPI? Perhaps you can eliminate the TPI bottleneck while still keeping the advantage of direct port fuel injection while switching to a "carb" intake...
Professional Products Hurricane or Edelbrock Victor E from Summit.
Or possibly cheaper on http://www.ebay.com/itm/SBC-Small-Block-Chevy-High-Rise-Hurricane-Aluminum-MPFI-EFI-Intake-Manifold-350-/390773513756?pt=Motors_Car_Truck_Parts_Accessories&hash=item5afbea9e1c&vxp=mtr.
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
I agree 4.11's will be fine. I also have a t56 with 3.73 and I can cruise at 75 with the tach at around 1800 to 2000 rpm's. Also for the speedo you will need a Dakota Digital recalibration box that for me took place of the vss buffer. It may be different on your year not sure. You are able to fine tune the signal.
Engine: 408 LSx
Thanks for the input guys.
Yeah, T56, so with the stock 245/50/R16's, in 6th gear I'd be at like 1800rpm with 4.11's.
I want to switch to carb for the simplicity. I realize both carburetor and fuel injection have their merits, but if I want to do the high performance FI thing, I'll either do an LS1 swap down the road or do something MegaSquirt. The harness in my car was messed with something nice so I want to avoid the headache and just go old school.
Plus, I have a complete 350 (2 bolt main) chilling in my garage with a bad crank (spun rod bearing) and no carb. It was pushing 375 in the Nova it was yanked from, and that was with a dinky 2-barrel.
I'm picking up a 350 (4 bolt main) with a 400 crank and 202 heads for 200 bucks from a buddy of mine.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
For the fan use a temp switch that grounds to turn on a relay for the fan
Read
https://www.thirdgen.org/forums/cool...-fan-come.html
and read
https://www.thirdgen.org/forums/cool...tched-pns.html
You can get most of the parts at autozone.
Get a 20A fuse holder
40A relay
http://www.autozone.com/autozone/acc...er=203873_0_0_
Relay holder or spade lugs
Wire
SW### sensor and pigtail then wire it all up
Or something like this
http://www.ebay.com/itm/Heavy-Duty-Electric-Fan-Relay-Kit-W-Thermostat-Ford-Chevy-Street-Rod-Race-Car-/151210528185?pt=Motors_Car_Truck_Parts_Accessories&hash=item2334d98db9&vxp=mtr
Read
and read
40A relay
Wire
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
