List of fan switched PNs / Threads / Connectors
Old Apr 20, 2012 | 08:36 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
All these part numbers are from the manufacturer wells. I hope this helps someone.
Common sensors for the thirdgen are
SW555
SW505
SW500
SW502
They can use the PT308 or PT770 pigtail
Code:
Cooling Fan Switch	Terminal No.	Terminal Type	Thread Size	Normal State	Specification
SW1009	2	Male Blade Terminal	M10 x 1.25
SW1010	2	Male Blade Terminal	M16 x 1.5	Closed	Breaks 185f ± 8 Makes 176f
SW1011	1	Male Blade Terminal	3/8 x 18	Open	Makes 225f ± 8
SW1012	2	Male Blade Terminal	M16 x 1.5	Open	Makes 209f ± 8
SW1120	2	Male Blade Terminal	M16 x 1.5	Open	Makes 194f ± 10%
SW1121	2	Male Blade Terminal	M17 x 1.30	Closed	Breaks 239f ± 10%
SW1122	2	Male Blade Terminal	3/8 - 19 BSPT	Open	Makes 221f ± 10%
SW1123	2	Male Blade Terminal	M16 x 1.5	Open	Makes 185f ± 10%
SW1422	3	Male Blade Terminal	M22 x 1.5	Open	Dual-Makes 174f ± 8 Makes 248f ± 8
SW1423	3	Male Blade Terminal	M22 x 1.5	Open	Dual-Makes 231f ± 8 Makes 259f ± 8
SW1425	2	Male Blade Terminal	M16 x 1.5
SW1426	2	Male Blade Terminal	M16 x 1.5
SW1428	3	Male Blade Terminal	M22 x 1.5		Operating range - 83/87
SW1429	3	Male Blade Terminal	M22 x 1.5
SW1431	2	Male Blade Terminal	M16 x 1.5		100f -1020? - 220f -163?
SW1433	2	Male Blade Terminal	M16 x 1.5	Closed	Breaks 209f ± 8
SW1434	2	Male Blade Terminal	M16 x 1.5
SW1435	2	Male Blade Terminal	M16 x 1.5	Closed	Breaks 204f ± 8
SW1436	1	Male Blade Terminal	M16 x 1.5	Open	Makes 204f ± 8
SW1437	2	Male Blade Terminal	M16 x 1.5	Closed	Breaks 210f ± 8
SW1438	2	Male Blade Terminal	M16 x 1.5	Open	Makes 215f ± 8
SW1440	2	Male Pin Terminal	        M16 x 1.5	Open	Makes 195f ± 8
SW1441	2	Male Blade Terminal	M16 x 1.5
SW1442	2	Male Blade Terminal	M16 x 1.5	Open	Makes 203f ± 8
SW1443	2	Male Blade Terminal	M16 x 1.5
SW1444	2	Male Blade Terminal	M18 x 1.5
SW1445	2	Male Blade Terminal	M14 x 1.5
SW1460	2	Female Terminal	        M16 x 1.5
SW1502	4	Male Blade Terminal		        Open	Dual-Makes 229f ± 10 - Makes 210f ± 10
SW1510	4	Male Blade Terminal	M22 x 1.5	Open	Dual-Makes 231f ± 10 - Makes 238f ± 10
SW1515	1	Male Blade Terminal	3/8 x 18	Open	Makes 211f ± 8
SW1630	1	Male Blade Terminal	M10 x 1.0
SW1632	2	Male Blade Terminal	M16 x 1.5	Open	Makes 217f ± 8
SW1634	4	Male Blade Terminal		        Open/closed	Closed-Breaks 250f ±8 -- Open-Makes 240f ± 8
SW1635	2	Male Blade Terminal	M10 x 1.00	Open	Makes 235f ± 8
SW1636	2	Male Blade Terminal	M18 x 1.5		Open 95c - Close 100c
SW1637	2	Male Blade Terminal	M10 x 1.00	Closed	Breaks 100f ± 8
SW1638	1	Male Blade Terminal	M10 x 1.00	Open	Makes 202f ± 8
SW1645	2	Male Blade Terminal	M16 x 1.5
SW1799	2	Male Blade Terminal	M10 x 1.00	Open	Makes 185f Breaks 176
SW1801	2	Male Blade Terminal
SW1802	2	Male Blade Terminal	M14 x 1.5	Open	Makes 200f Breaks 185f
SW1803	2	Male Blade Terminal
SW1820	2	Male Pin Terminal	M22 x 1.5		Range: 95/90
SW1821	3	Male Blade Terminal	M22 x 1.5
SW1822	2	Male Blade Terminal	M22 x 1.5
SW1824	3	Male Blade Terminal	M22 x 1.5
SW1825	3	Male Blade Terminal	M22 x 1.5
SW1828	2	Male Blade Terminal	M22 x 1.5		Range:96c/91c
SW1829	3	Male Blade Terminal	M22 x 1.5
SW1833	2	Female Terminal	5/8 x 18
SW1834	2	Female Terminal	M16 x 1.5
SW1842	1	Male Blade Terminal	M16 x 1.5	Closed	Breaks 120f ± 8
SW1887	2	Male Blade Terminal	M16 x 1.5	Open	Makes 93c ± 3
SW1888	2	Male Blade Terminal	M18 x 1.5	Open	Makes 199f Breaks 190f
SW1895	2	Male Blade Terminal	M16 x 1.5
SW1902	2	Male Blade Terminal	M12 x 1.5	Closed	Breaks 221f Makes 210f
SW1957	2	Male Blade Terminal	M22 x 1.5	Open	Makes 197f Breaks 188f
SW1958	3	Male Pin Terminal	M22 x 1.5	Open	Dual-Makes 197f Breaks 188 -- Makes 222f Breaks 213f
SW2021	1	Male Blade Terminal	3/8 NPT	Open	Makes 224f Breaks 218f
SW2022	1	Male Blade Terminal	3/8 NPT	Open	Makes 234f Breaks 228f
SW2032	1	Male Blade Terminal	M21 x 1.5
SW2164	1	Male Blade Terminal	M16 x 1.5
SW2378	2	Male Blade Terminal
SW2379	2	Male Blade Terminal	M18 x 1.5
SW2380	2	Male Blade Terminal	M15 x 1.00
SW2400	2	Male Blade Terminal	M16 x 1.5
SW2883	2	Male Pin Terminal   	M16 x 1.5
SW2902	2	Male Blade Terminal	M15 x 1.00
SW3009	2	Male Blade Terminal	M16 x 1.5
SW3011	3	Male Pin Terminal	        M14 x 1.5		Range 91/104c
SW3012	3	Male Pin Terminal	        M14 x 1.5		Range 91/99c
SW3013
SW3014	2	Male Blade Terminal
SW3016	2	Male Terminal	        M16 x 1.5		Stamped 115° Off
SW3017	2	Male Blade Terminal	M16 x 1.5
SW3156	2	Male Blade Terminal	M22 x 1.5
SW3157	2	Male Blade Terminal	M22 x 1.5
SW3375	1	Male Blade Terminal	M17 x 1.25
SW3376	2	Male Pin Terminal    	M22 x 1.5
SW3459	2	Male Blade Terminal	ID .375-25UNF
SW3696	2	Male Blade Terminal
SW3721	2	Male Blade Terminal
SW3729	3	Male Blade Terminal	M22 x 1.5		102°/95°
SW4075	2	Male Blade Terminal	M22 x 1.5		95°
SW4088	2	Male Blade Terminal	M10 x 1.5
SW4139	2	Male Pin Terminal	ID     M10 x1.5
SW4244	2	Male Blade Terminal	M16 x 1.5
SW4247	3	Male Pin Terminal	        M14 x 1.5		80°/88°c
SW4248	3	Male Pin Terminal	        M14 x 1.5		80°/88°c
SW4293			                        M16 x 1.5
SW4374	3	Male Blade Terminal	M22 x 1.5	Open	Dual-Makes 101c Breaks 93c--Makes 213c Breaks 200c
SW4376	2	Male Blade Terminal	M10 x 1.0
SW500	1	Recessed Post	        3/8 x 18	Open	Makes 230f ± 8
SW501	1	Male Bullet Terminal	3/8 x 18	Open	Makes 222-239 f
SW502	1	Recessed Post	        3/8 x 18	Open	Makes 238f ± 8
SW503	1	Male Bullet Terminal	M16 x 1.5	Open	Makes 208f ± 14
SW504	2	Male Blade Terminal	M16 x 1.5	Open	Makes 204f ± 8
SW505	1	Recessed Post	        3/8 x 18	Open	Makes 221f ± 8
SW506	2	Male Blade Terminal	M16 x 1.5	Open	Makes 194f ± 8
SW507	1	Male Bullet Terminal	M16 x 1.5	Open	Makes 204f ± 8
SW508	1	Blade Terminal	        M16 x 1.5	Open	Makes 190f ± 9
SW509	3	Male Blade Terminal	M22 x 1.5		1) Opens 185f Closes 203f 2) Opens 188f Closes 215f
SW510	1	Male Bullet Terminal	3/8 x 18	Open	Makes 210f ±10 Opens 185
SW511	1	Male Blade Terminal	M16 x 1.5	Open	Makes 194 ± 3
SW512	1	Blade Terminal	        M16 x 1.5	Closed	Breaks 201f ± 8
SW513	1	Blade Terminal	        M16 x 1.5	Open	Makes 238f ± 8
SW514	2	Male Blade Terminal	1/2 x 14	Open	Makes 200f ± 10 Opens 170f
SW515	1	Male Blade Terminal	M16 x 1.5	Open	Makes 105c ± 10
SW516	1	Blade Terminal	        M16 x 1.5	Open	Makes 105c ± 3 Opens 98c ± 4
SW517	2	Male Blade Terminal	M16 x 1.5	Closed	Breaks 90c ± 3 Makes 83c ± 4
SW518	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ± 3 Breaks 83c ± 4
SW519	2	Male Blade Terminal	M16 x 1.5	Open	Makes 95c ± 5 Breaks 90c ± 5
SW520	1	Male Bullet Terminal	M16 x 1.5	Closed	Breaks 97c ± 3 Makes 92c
SW521	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ± 3 Breaks 83c ± 4
SW522	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ±3 Breaks 83c ± 4
SW523	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ±3 Breaks 83c ± 4
SW524	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ±3 Breaks 83c ± 4
SW525	2	Male Blade Terminal	M16 x 1.5	Open	Makes 92c ± 3 Breaks 82c ±4
SW526	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ± 3 Breaks 83c ± 4
SW527	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c ± 3 Breaks 83c ± 4
SW528	2	Male Blade Terminal	M16 x 1.5	Open	Makes 105c ± 3 Breaks 98c ± 4
SW530	2	Male Blade Terminal	1/2 x 14	Open	Makes 184f ± 7 Breaks 159c
SW531	2	Male Blade Terminal	1/2 x 14	Open	Makes 210f ± 10 Breaks 185 f
SW532	2	Male Blade Terminal	1/2 x 14	Open	Makes 212f ± 5 Breaks 192 f
SW533	2	Male Blade Terminal	M22 x 1.5	Open	Makes 203f ± 5 Breaks 194f ± 5
SW535	1	Male Bullet Terminal	M16 x 1.5	Closed	Breaks 203f ± 6 Makes 194f ± 6
SW536	2	Male Blade Terminal	M16 x 1.5	Open	Makes 190f ± 6 Breaks 174f ± 6
SW539	1	Blade Terminal	        M16 x 1.5	Closed	Breaks 206f ± 8
SW541	1	Male Bullet Terminal	1/4 x 19	Open	Makes 218f ± 9 Breaks 209f ± 9
SW542	2	Male Blade Terminal	M16 x 1.5	Open	Makes 170f ± 8
SW543			                        M16 x 1.5
SW544	2	1 Male 1 Female Bullet	M22 x 1.5	Open	Makes 210f ± 8
SW546			M16 x 1.5	Open	Makes 198f ± 9 Breaks 189f ± 9
SW547	1	Blade Terminal	        3/8 x 18	Closed	Breaks 122f ± 9 Makes 113f ± 9
SW548			                        M16 x 1.5	Closed	Breaks 194f ± 9 Makes 185f ± 9
SW551	1	Blade Terminal	        M16 x 1.5	Closed	Breaks 203f ± 9 Makes 194f ± 9
SW552	2	Male Blade Terminal	M22 x 1.5	Open	Makes 199f ± 8
SW553	2	Male Blade Terminal	M22 x 1.5	Open	Makes 217f ± 9 Breaks 208f ± 9
SW554	2	Male Blade Terminal	M16 x 1.5	Open	Makes 203f ± 5 Breaks 194f ± 5
SW555	1	Female Terminal	        3/8 x 18	Open	Makes 210f Breaks 205f
SW556	2	Male Blade Terminal	M22 x 1.5	Open	Makes 197f-208f Breaks 177f-188f
SW557	1	Blade Terminal		Open	Makes 212f ± 9 Breaks 203f
SW560	1	Male Bullet Terminal		Open	Makes 198f ± 8
SW562	2	Male Blade Terminal	M16 x 1.5	Open	Makes 204f ± 8
SW563	2	Male Blade Terminal	3/8 x 18	Open	Makes 63f ± 8
SW565	2	Male Blade Terminal	M22 x 1.5	Open	Makes 224f ± 6 Breaks 210f ± 6
SW566	2	Male Blade Terminal	M16 x 1.5	Open	Makes 190f ± 8
SW567	2	Male Blade Terminal	M22 x 1.5	Open	Makes 198f ± 5 Breaks 180 ± 5
SW568	2	Male Blade Terminal	1/4 x 19	Closed	Breaks 147f ± 8
SW569	2	1 Male 1 Female Blade	3/8 x 18	Closed	Breaks 128f ± 8
SW571	1	Male Pin Terminal		Open	Makes 226f ± 8
SW572	2	Male Blade Terminal	M14 x 1.5	Open	Makes 99c
SW576	2	Male Blade Terminal	M16 x 1.5
SW577	2	Male Blade Terminal		Closed	Breaks 174f ± 8
SW578	3	Male Pin Terminal	        M22 x 1.5	Open	Dual-Makes 92c Breaks 82c - Makes 96c Breaks 82c
SW580			                       13/16 x 14 unc	Open	Makes 228f ± 8
SW581	2	Female Pin Terminal	M22 x 1.5	Closed	Breaks 210f ± 8
SW583			                        1/2 x 14	Open	Makes 224f ± 8
SW585	2	Male Blade Terminal	M22 x 1.5	Open	Makes 203f ± 6 Breaks 194f ± 6
SW586	2	Male Blade Terminal	M22 x 1.5	Open	Makes 198f ± 5 Breaks 189 ± 5
SW587	2	Male Blade Terminal	M16 x 1.5	Open	Makes 90c Breaks 85c
SW588	2	Male Blade Terminal	M22 x 1.5	Open	Makes 140f ± 9 Breaks 122f ± 9
SW589	2	Male Blade Terminal	M16 x 1.5	Open	Makes 210f ± 8
SW590	2	Male Blade Terminal	M16 x 1.5	Open	Makes 185f ± 9 Breaks 176f ± 9
SW591	2	Male Blade Terminal	3/8 x 18	Open	Makes 185f ± 8
SW592	2	Male Pin Terminal	        M16 x 1.5	Open	Makes 194f Breaks 185f
SW593	2	Male Blade Terminal	M22 x 1.5	Open	Makes 110c ± 5 Breaks 115c ± 5
SW594	2	Female Pin Terminal	M22 x 1.5	Open	Makes 198f ± 9
SW595	2	Male Pin Terminal		                Open	Makes 198f ± 6 Breaks 189f ± 6
SW611	1	Male Blade Terminal	M16 x 1.5	Open	Makes 194f ± 9 Breaks 185f ± 9
SW648	2	Male Blade Terminal	M18 x 1.5	Open	Makes 216f ± 8 Breaks 206f ± 8
SW649	1	Male Blade Terminal	3/8 x 18	Open	Makes 223f ± 8
SW650	3	Male Blade Terminal	M22 x 1.5	Open	Dual-Makes 189f ±8 Breaks 170f ±8 Makes 198f ±8 Brea
SW651	2	Male Blade Terminal	M16 x 1.5
SW652	1	Male Blade Terminal	M16 x 1.5	Closed	Breaks 197f ± 8
SW653	1	Male Blade Terminal	M16 x 1.5	Closed	Breaks 200f ± 8
SW740	2	Male Blade Terminal	M16 x 1.5	Open        	Makes 216f ± 5 Breaks 206f ± 5
SW741	2	Male Pin Terminal	        M16 x 1.5	Closed	Breaks 234f ± 5 Makes 224f ± 5
SW940	3	Male Pin Terminal	        M14 x 1.5
SW956	2	Male Blade Terminal	M14 x 1.5
TU192	2	Male Pin Terminal	        M16 x 1.5	Closed	Breaks 158 ± 8 Makes 137f min
TU244	1	Male Blade Terminal	3/8 x 24	Open	        Makes 140f ± 8
TU269	2	Male Blade Terminal	M16 x 1.5	Open        	Makes 220f ± 8
TU325	1	Male Blade Terminal	M10 x 1.0
TU342	2	Male Blade Terminal	M15 x 1.00
TU344	2	Male Pin Terminal	        M14 x 1.25
TU367	1	Male Blade Terminal	M16 x 1.5
Old May 22, 2012 | 10:28 AM
midias's Avatar
Re: List of fan switched PNs / Threads / Connectors
Updated with pigtail PNs
Old Feb 12, 2018 | 02:27 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Old May 19, 2022 | 05:44 AM
Bavooz Flo's Avatar
Car: FIREBIRD TRANS AM GTA 1987
Engine: 5.7
Transmission: th700
Hello,
I have a SW505 since a few time and I would like to install on my car but question for me ........ the SW505
Code:
Open Makes 221f ± 8 OK but and
breaks at ?????
SW555
SW505
SW500
SW502
Code:
SW3013
SW4293 M16 x 1.5
SW543 M16 x 1.5
Borsty
Dec 19, 2004 11:44 PM
Yellow Camaro
Feb 12, 2003 07:58 PM
Z-drr-Guy
19
Sep 6, 2002 03:05 PM
