throttle cable help for 350 carb
Old Mar 15, 2014 | 12:12 AM
86camaro454's Avatar
iv been looking around and trying to find a good stong throttle cable so when i hit the gas it dont brake as any one used this or recommend one that is real good
http://www.summitracing.com/parts/lo...6/model/camaro
Old Mar 15, 2014 | 01:10 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: throttle cable help for 350 carb
i used my stock cable, worked just fine with one of these ... http://www.summitracing.com/parts/sum-g1414/overview/
Old Mar 15, 2014 | 10:52 AM
well my car did not have one when i bought it and i have a mount
Old Apr 21, 2014 | 01:43 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Whoa bro! In the Applications area it says "Notes: Fits models with TPI only."
Don't, want you to spend +55 on a cable that won't fit XD
Good luck!
Old Apr 21, 2014 | 06:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you have throttle cables breaking when you step on it, then the cable itself isn't the problem.
Old Apr 21, 2014 | 07:50 PM
Damon's Avatar
A throttle cable from an earlier carbureted F-body usually suffices with the proper carb bracket.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
