just bought edelbrock 1406
So im pretty sre the fuel inlet is completly different then the stock rochester. I have a edelbrock line that is just like a extention that goes down and then out. But will i need to like cut my fuel.line and use a rubber hose or aomething to get it to.fit? It says i just bolt it on but im pretty sure thats not the case
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: just bought edelbrock 1406
Looks like the adapter uses an AN fitting.
Also you will need a new manifold or adapter. You also wont gain any power over a well running Qjet. You will also lose MPGs.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yeah you need supporting mods. If you're stock otherwise and just replacing the carb it's probably better to rebuild the quadrajet.
No guys my old qjet went to ****. Secondaries wouldnt open and alot other things. I will soon be gettin a new manifold. My carb currently is runnig so rich its flooding my motor. So im getting like 5 mpg. Pretty sure the edelbrock will do better then that lol
Why not get a new Q jet?
Well it is your car. If it is a stock 305 the 1406 should be good, if it is modified or a 350 then change the jetting to the 1405
As for new advice I am done so just Click Here
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
