Q-jet won't idle?
Subscribe
Apr 24, 2014 | 11:32 AM
i have a 85, 305 with the rochester quad, no computer, and computer related all torn out, its in a 89 firebird with fuel press regulated, fuel pressure at 5psi (in line press gauge) I got the carb from summit racing, friend gets great discounts, put the carb on, adjust the fuel pressure, will start and run, but won't idle too great, and put into gear it dies, the electric choke is working, but to restart it after it dies, i have to pump the gas pedal while cranking it!??! No vacuum leaks, brand new complete secondary ignition, dist, plugs, wires ,cap ,rotor, coil.....if i hold the rpm around 900, it runs great? Any ideas would be much appreciated! Thanks in advance!
Reply 0
Apr 24, 2014 | 11:42 AM
Re: Q-jet won't idle?
is it flooding it at an idle or no fuel?
Reply 0
Apr 24, 2014 | 11:53 AM
Te pressure gauge (about 6inches) from carb inlet stays a 5psi. I haven't had anybody to look into the card while i was cranking it after it stalls out? So I'm guessing its getting fuel if the gauge stays a 5psi? Its a rebuilt carb from summit, so i assume it wouldn't need much adjustment?
Reply 0
Apr 24, 2014 | 12:22 PM
Quote: Its a rebuilt carb from summit, so i assume it wouldn't need much adjustment?
Foolish unless the guy from summit built and tested it on your car.
Did you at least try to adjust the idle mixture or speed screws?
What is your base timing?
Reply 0
Apr 24, 2014 | 12:34 PM
Quote: Foolish unless the guy from summit built and tested it on your car.
6 degress btdc i have tried adjusting the idle mixture screws, and moving the diet a little each way, doesn't fix problem, I'm not too great at adjusting carbs, thats why I'm asking here. Thanks
Reply 0
not moving "die" lol, diet.....
Reply 0
Apr 24, 2014 | 12:35 PM
stupid typing! Moving the dist!
Reply 0
Apr 24, 2014 | 12:44 PM
Quote: 6 degress btdc i have tried adjusting the idle mixture screws, and moving the diet a little each way, doesn't fix problem, I'm not too great at adjusting carbs, thats why I'm asking here. Thanks
How about the idle speed screw?
Reply 0
Apr 24, 2014 | 12:50 PM
No, i have not. How exactly do you go about doing that, meaning, is there a "special" way or something? Like i said, not too good with carbs! Is that the adjustment on the choke side, or the one on the linkage side?
Reply 0
Apr 24, 2014 | 12:54 PM
Quote: No, i have not. How exactly do you go about doing that, meaning, is there a "special" way or something? Like i said, not too good with carbs! Is that the adjustment on the choke side, or the one on the linkage side?
Without knowing exactly which one you bought there still should be a screw with a spring under it near the throttle linkage. Turn that in until you get to your desired idle then use the idle mixture screws to fine tune it.
Reply 0
Apr 24, 2014 | 12:58 PM
Ok, i will give that a shot as soon as i get home from work! Thanks for your help! If you don't mind, check back on this thread sometime, in case i have questions. Again, thanks!!
Reply 0
Apr 24, 2014 | 02:02 PM
I agree I would check the idle speed screw, I don't know what carb model you have but if you give it too much on the Idle speed screw just to keep it alive because of other issues it will start to turn on the primary side and be dog rich at an idle.. usually if you have a lumpy cam and don't have it adjusted people will keep going with the screw to stay alive and they run super rich at an idle
Reply 0
Subscribe
