inline fuel pump pictures
Old Apr 28, 2014 | 02:28 PM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
Transmission: automatic
I have done a lot of research and came to the conclusion that mounting the pump on the well on the backseat is probably going to be my best bet. I would like some final advice before I start drilling and more importantly a picture or two would help tremendously. thanks.
Old Apr 28, 2014 | 05:34 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: inline fuel pump pictures
A inline pump should be mounted as low to the tank as possible, They are designed to push fuel not pull fuel. Mounting low will cause a siphon effect after startup and reduce the pump having to pull the fuel continuously, Which can cause overheating and pump damage.....
Old Apr 29, 2014 | 07:28 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
^what he said^
I don't have pics but mine is mounted on the driver's side of the tank, almost flush with the bottom of the tank.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
