mpfi to carbed 350 help
Car: 1986 camaro
Engine: 2.8L v6 multiport injection
Transmission: 5-speed
so im planning on doing a swap from my 2.8 mpfi v6 to a carb'd 350. dont want to drop my tank so planning on leaving the stock fuel pump in the tank and running a fuel pressure regulator. just trying to get a better understanding of how to set this up. any tips? pictures would help alot too. thanks
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: mpfi to carbed 350 help
Thats all you need to keep the stock in-tank fuel pump.
It's really a simple set up.
Car: 1987 Camaro 1991 camaro rs
Engine: 305 and 350
Im doing the same swap but i have a hacked up harness wat wiring do i need to run if i only have the bulkhead only wires but cut ?
Car: 1998 Camaro Z28
Engine: 6.0L
That's a vague question, what all do you plan to run? Just the very basics to start and drive the car or do you want a fully functional interior, cluster, etc?
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
