fuel pump help
Car: 1988
Transmission: 5 spd
fuel pump help
Recently aquired an 88 camaro with a 305 carb swap. Car was originally a v6 so I pulled all computer related stuff outta the car to clean up the engine bay. The car had a Mr gasket pump mounted on the drivers fender. Does that mean that the in tank pump was already taken care of or will I have to figure something out from pulling the ecm out
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: fuel pump help
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
