wide band o2
Old Jun 29, 2014 | 09:49 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
wide band o2
not sure where to put this so since im using it to tune a carb I guess her might work.
looking for a wide band o2 with data logging. just wondering what some of you guys are using.
Old Jul 4, 2014 | 05:41 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
Re: wide band o2
you don't need datalog for a carb tuning all you need is a vacuum gauge and a widebande,
they are all pretty much the same, i have a prosport evo series on the camaro and the same one on the Hyundai Genesis to tune the 16G turbo and they work great
Old Jul 4, 2014 | 10:07 PM
ziggy89's Avatar
Engine: 383
Re: wide band o2
Why a vacuum gauge for tuning?
Old Jul 4, 2014 | 10:30 PM
camarito's Avatar
Re: wide band o2
That's the only way to see throttle position/engine load and correct carb circuit activation
Old Jul 5, 2014 | 03:03 AM
ziggy89's Avatar
Engine: 383
Re: wide band o2
No power valve. But it does have vacuum secondarys. But if i tune it for wide open open throttle I'm sureni won't come up lean on part throttle which is all I'm worried about. Not a dd just a fun car.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Vincent135
Sep 28, 2015 10:50 PM
