choke light flickering and clicking under the dash
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
recently my choke light has start flickering (it comes and goes). There is a definite click under the dash in the group of stuff above the gas pedal. I tried to get in there to figure it out but thought I would ask here and get some insight into what might be causing it.
I disconnected the electric choke and it still didn't stop it. I'm seeing posts in other threads about the alternator and the choke light but am wondering about the "on/off clicking" that I'm hearing with the flickering. The alternator is a few months old, Put it in with the engine swap last fall.
ideas?
thanks!
ideas?
thanks!
Re: choke light flickering and clicking under the dash
Yup, needs an alternator.
Don't outsmart yourself over "click" and all that. That's how they behave sometimes.
If I recall correctly, there is a choke relay under there. Could be the source of the clicking. Not sure if there is a tie-in with the alternator, but the alternator is always the first suspect in the line-up whenever you see the choke light come on.
Yessir, you mos def recall correctly.
The relay is in parallel with the light; they operate together. Light on = relay drops out. Light off = relay picks up.
Car: '83 TA
Thanks for the replies, guys. I noticed last night that the voltage on the meter on the dash is surely fluctuating a bit. Especially if I hit the defroster and turn the blower fan on high and also when I slow down and come to a stop. But I also noticed that the "clicking and light flickering slows way down or goes away completely as the voltage on the dash drops. i would have thought that the light would come on all the way in that case. so I'm a bit confused about that.
but the dang thing is virtually new. It has a few thousand miles over a couple years with that Alt. I'm wondering if I should check grounds first. Well...second. first I'm gonna put a volt meter to the Alt. But bad grounds could cause a problem with virtually everything right?
It's killing me to think that Alt could be bad with so little use.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: '83 TA
Where would you recommend I get one and which particular one should I get?
I'm still finding a few things very odd about all this though.
1. I took the time to clean off a couple of grounds and the voltage instantly increased and the flickering/clicking frequency immediately reduced.
2. Why does the flickering/clicking go away if I add more load to the circuits (turn on the defroster and high fan)?
3. Why does it slow and stop flickering/clicking when I come to a stop and increase in speed and frequency again as I accelerate as voltage seems to increase?
Pilotrick50
Sep 2, 2015 12:48 PM
