Fuel Pump Issues after TBI to Carb Swap
Old Sep 3, 2014 | 08:14 PM
JrBrein1988's Avatar
Car: 1988 Pontiac Firebird
Engine: LO3 5.0 (305) TBI
Alright. I have just finished swapping my 305 TBI to 350 Carb and I am getting tripped up on the fuel delivery. When the ecm is unplugged, the fuel pump wont run at all. Does the ecm directly control the fuel pump? When the fuel pump did work it pulsed for about 5 seconds the dropped. Any ideas on how to get the electric in tank fuel pump working without the ecm? Thanks in advance.
Old Sep 3, 2014 | 11:30 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Fuel Pump Issues after TBI to Carb Swap
there should be a relay on the drivers side firewall near the fender. you will have to tap a switched 12v wire into one of the wires on the relay. hold on let me get a pic for you
Old Sep 3, 2014 | 11:40 PM
you will need it find a pink wire with a black stripe, those are all 12v switched. then tap that wire into the green with white stripe wire on your fuel pump relay. here is a pic.
[IMG]20140903_233316 by , on Flickr[/IMG]
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
