another what will it run
Old Oct 6, 2014 | 08:06 PM
88lt1's Avatar
91 z28 383
10.7:1 comp.
234 242 .588 .595 114 with 1.6rr
old afr 190's
edelbrock rpm air gap
holley 750 dp
1 3/4" slp shorties with dyno don y-pipe
3" out the back
turbo 350 with custom 3500 stall ptc nitrous converter
stock 10 bolt with girdle 3.23 gear
founder lca and panhard
spohn adj tq arm
275 50 mt radial
guessing it weighs 3400
I'm thinking 7.80 in the 1/8 mile on motor maybe 6.80 on 150 shot on a progressive to save the 10 bolt till i can afford a 9in. Got a 2014 5.0 I need to getaround. he runs 6.90@103mph on 100 shot
Old Oct 8, 2014 | 09:49 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: another what will it run
I think 7.60's NA and 6.80's on the 150 are reasonable goals. So much depends on the tune. You're a little under-geared, especially NA.
Your buddy in the Furd is not getting off the line at all running only 6.90 ET. His trap speed shows capablility of 6.60
Old Oct 8, 2014 | 11:12 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
3.73 is normally the best gear for a car like that. if you have the stock diff or open thats going to hurt, and if its stock weight any thing you can live without will help. i got rid of a few big black garbage bags of junk when i was racing mine.
Old Oct 8, 2014 | 11:47 AM
88lt1's Avatar
The mustang is a standard that is why he is leaving et on the table. The rearend is stock want to leave the gear ratio alone because it is still driven on the street some. 3.23 = 2900rpm @70 with 245 50 16s. thanks for your replies just need to finish getting it together. The motor was built for the bottle so when the rear end is upgraded ill hit it with 250 shot that ought to take care of the mustang.
Old Oct 8, 2014 | 11:54 AM
86LG4Bird's Avatar
Originally Posted by 88lt1
...when the rear end is upgraded ill hit it with 250 shot that ought to take care of the mustang.
LOL........it better!
Old Nov 16, 2014 | 04:18 PM
rolljitsu's Avatar
Car: 91 camaro rs
Engine: 305 l03
Axle/Gears: stock
91 z28 383
10.7:1 comp.
old afr 190's
holley 750 dp
3" out the back
spohn adj tq arm
275 50 mt radial
Needs more gear, victor or team g manifold, and most likely more converter but you will save alot of broken parts ruining it this way. But you have alot left in this build keep I'd posted
Old Nov 16, 2014 | 04:22 PM
rolljitsu's Avatar
Car: 91 camaro rs
Engine: 305 l03
Axle/Gears: stock
Quote:
Originally Posted by 88lt1 View Post
91 z28 383
10.7:1 comp.
old afr 190's
holley 750 dp
3" out the back
spohn adj tq arm
275 50 mt radial
Needs more gear, victor or team g manifold, and most likely more converter but you will save alot of broken parts running it this way. But you have alot left in this build keep us posted
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
