positive wire of inline electric fuel pump
Old Oct 16, 2014 | 04:08 AM
G_FORCE32's Avatar
I have my positive wire of my inline electric fuel pump wired to a toggle switch. Wanted to rewire to something else. Is there any power source within the engine bay that i can connect to?
Old Oct 16, 2014 | 06:41 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: positive wire of inline electric fuel pump
it needs to be wired to a relay, easiest thing to do is wire it to the pump output of the stock relay. since you didnt say what car you have, you can look on austin third gen for your yr/model/engine diagram and that will tell you what wire to use.
Old Oct 16, 2014 | 06:58 AM
G_FORCE32's Avatar
Thnx jw. Likewise its a 92 tbi conv to carb. Where is the stock relay and what color wire should i tap into?
Old Oct 17, 2014 | 06:39 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
on my 87 it was behind the brake booster area. it says its a gray wire. do you still have the pcm hooked up? if not hook up the dk green/white trace wire to a key on 12v
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
