350 HO vs electric fuel pump
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
My 91 RS is a 305 TBI, and I may be swapping the blown 305 out for a GM 350 High Output carbed engine. My question is, since carbs dont need a lot of fuel psi, would the tbi pump be enough? I wpuld throw a regulator on to get to the desired psi, but would it be applicable?
Car: 1988 Camaro
Re: 350 HO vs electric fuel pump
The stock TBI 305 pump reg'ed down to 5psi will work fine for street use and red light to red light fun. It does not have enough volume to support 400 HP and WOT at the drag strip run 6K rpm..
It will work find for street and mild performance though
Car: 1991 Camaro RS
Engine: 5.0 L03
Very nice. The 350 HO only puts out 330 horsepower, so it should be fine. Plus it only makes power to around 5200 so blammo. Any suggestions on fuel regulators?
Car: 1988 Camaro
I have not done a EFI to carb swap with the in-tank pump in years, so I don't know if there is any better regulators out now, but the one I use to use was the Mallory 4309 that was about $80-90
Car: 1983 G20 Chevy
Transmission: 4L60
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A few notes about the Holley 600. Though the carb may have changed since I purchased my 350HO, you might take a peek:
https://www.thirdgen.org/forums/carb...ey-tuning.html
BTW, I ran an OE mechanical pump for years before swapping for a high-flow Carter.
JamesC
JamesC
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
That mallory unit is the general consensus one to use here judging by what most people post. There are other manufacturers that also make an adjustable regulator in the 4-7psi range.
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
