help with carb swap vac lines
Old Dec 14, 2014 | 01:15 PM
xxredsbirdxx's Avatar
I have a 305,700r4 with the q-jet but replacing it with a edelbrock 1406, ripping out all emissions and I know the booster connects to the back and I got pcv in the front middle, but there's 2 other little vac ports in front on each side I think ones a ported and one is a constant vac that I've found from researching, but the q-jet had like 6 vac lines out of it. Wondering if all the lines from the q-jet were for emissions? Or do I just cap the 2 on the edelbrock or is there something I got to connect to it from the q-jet set up? Sry this it's my first carb swap. And thanks in advance.
Old Dec 15, 2014 | 06:01 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: help with carb swap vac lines
Should run dizzy vac advance to the ported vac. Everything else to manifold vac. Least that's now I would do it.
Old Dec 17, 2014 | 01:55 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Vacuum advance goes to manifold vacuum in my opinon. Ported vacuum is an emissions era crutch and a poor one at that.
Old Dec 17, 2014 | 07:18 PM
ziggy89's Avatar
Engine: 383
It goes both way . My msd dizzy said run it to ported vac. I don't even run vac advance if that says anythin .
Old Dec 17, 2014 | 09:30 PM
Night rider327's Avatar
Car: 1988 Camaro
Vac advance is a very good thing for any street use engine, and street/strip type cars really. Ported or full vac is a long time debate.. I find it best to try both ways for a while, maybe 20-30 miles if it's a weekend car, a tank full of fuel if daily driver, or 4 passes at the track if race only.
Use the vac source that gives you the best all around results.
I will say this though, most of mine likes full vac better than ported/timed.
Using vac advance will get better fuel mileage, clean up the idle some, keep plugs cleaner longer, can help you to get a big cammed engine running/idling better, give you the high timing you need at idle and part throttle w/o the worry of detonation at WOT due to, too much timing, etc.
Old Dec 18, 2014 | 12:13 AM
ziggy89's Avatar
Engine: 383
Yeah I know it improved gas mileage but being a weekend warrior I wasn't to concerned with gas mileage.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
