In tank fuel pump
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
In tank fuel pump
Does anybody see an issue with me jumping out the fuel pump to see if it works and then to pump about 3 gals of fuel out of the tank ? I got this car ( 87 Iroc Z ) as a roller, I don't know if the in tank pump works, also there is about 3 gals of gas in the tank that I would like to get out of the tank and really don't want to have to drop the tank. If the pump does not work I know I will have to drop the tank.
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: In tank fuel pump
No problem. Just be sure you watch the gas and when the tank is "empty", shut the pump off so it doesn't overheat and burn up.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Very important to not run the pump dry. It'll last moments if it is.
Car: 87 Iroc Z 28
Thanks Bigal55 and Ozz1967, everything went as planed. Pump worked fine and got old gas out of tank.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
