how do are throttle cables connect?
Old May 20, 2015 | 01:50 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I have a 86 iroc swapped from tpi to carb and got a shorter throttle cable and I have no idea on how to change one need some help
Old May 20, 2015 | 01:51 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
Re: how do are throttle cables connect?
This is what I go from advance
Old May 20, 2015 | 08:08 PM
Damon's Avatar
That can't be the right cable. This is what it looks like (it's on my 1990 454SS truck, but GM used this style of carb connection since the mid 70s):
OK, so that photo stinks. If it was at all legible you'd see the throttle cable end is nothing but an eyelet with a hole that slides over a matching-sized stud and is retained by either a special clip (factory-style throttle cable stud) or a cotter pin or some such contrivance (as is the case with my aftermarket unit). Here's what the stud looks like and where it goes in a Holley throttle arm:
You can't see it in the photos but the cable head where it clips into the throttle cable bracket behind the carb is square. Order a cable for an 86 Camaro with the 5.0L CARBURETED (LG4) engine and you'll have what you need. Proper style throttle cable stud you can get from Holley, Edlebrock or a bunch of different places. Throttle cable BRACKET is the real key to all this. Adapting a factory one is often frustrating when using an aftermarket carb intake. Much better to get an aftermarket (adjustable) one that bolts to the carb instead of the intake manifold. That way you can easily swap it over no matter what intake you're using.
Old May 20, 2015 | 08:19 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
I know how it connects to the carb im saying the opposite end where it goes into the fire wall
Old May 22, 2015 | 12:24 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
The end you pictured connects to the accelerator pedal. Its a real pain to do, I just bought a carb throttle plate and used my EFI linkage.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
