Mounting regulator on block
Old Jun 19, 2015 | 08:50 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Hey guys.
Has anyone ever mounted their fuel pressure regulator on the block where the mechanical pump would be?
If so, how did you mount it?
And, did you fab up a hardline, or use flexible braided?
Old Jun 19, 2015 | 09:06 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Mounting regulator on block
I don't see why you couldn't fab up a mount bracket and mount it there, I've also seen a few mounted to the front of the driver's side head, where the A/c bracket would be on an A/C equipped car; and yeah, most folks use flex line.
Old Jun 20, 2015 | 07:49 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i put mine on the fender where there was a cruise actuator on my 6cyl car, to me it seems like a safety issue, if you have drips which always happen, i would rather it be away from the hot engine and exhaust. also need to be able to see the gauge and adjust the screw
Old Jun 26, 2015 | 08:26 AM
Manic Z's Avatar
Looks like I won't be able to mount it to the block anyway. Even with a 90 degree fitting, the inlet touches the motor mount.
Does the regulator really need to be bolted to anything? Can it be 'supported' by the lines themselves?
Old Jun 26, 2015 | 10:25 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I personally wouldn't. I have mind mounted to the passenger side strut tower.
Old Jun 26, 2015 | 10:32 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
rlewi771 did it on his car but the only picture I could find of it doesn't show it in detail.
Old Jun 26, 2015 | 11:40 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I just fabbed up a quick bracket. This was during the test fitting and construction process.
9192camaro
16
Feb 3, 2019 12:21 AM
evan555222
Sep 20, 2016 02:51 AM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
evan555222
Aug 22, 2015 07:14 PM
