84 camaro project new to carbs
Old Jul 17, 2015 | 03:38 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
okay so I just picked up a 84 305 camaro stock carb stock dizzy, AIR delete and egr. we can get it to start fairly easy doesn't idle well (have to hold it at about 1500 rpm) and will drive but wont accelerate. We just found out that the dizzy advance wasn't hooked up so we connected that went for a drive and same thing but this time it over heated when we got back, also it sounds like there is a miss when you give it any sort of gas. I am use to fuel injected but computer controlled carb is confusing as all hell, so I suppose first off what all sensor are on this that would effect drive ability (the trans to it is acting up)?
Old Jul 22, 2015 | 10:46 AM
Blackfell's Avatar
Re: 84 camaro project new to carbs
First try the obvious, give it a full tune up. After that find someone that knows how to properly tune the cc-qjet. If the issue still continues then the carb might not be an issue. Also might check your timing. Other than that I don't know what direction to go.
Old Jul 22, 2015 | 03:07 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you're running the ccc carb with a vac advance dist? it will never work right.
Old Jul 22, 2015 | 06:18 PM
nuggie's Avatar
it'll start and run pretty well just won't idle or accelerate right now we are running the stock dizzy and carb but was looking at swapping it over to vac and non cc carb I dunno I would really like this set up just to friggen work
Old Jul 22, 2015 | 06:32 PM
nuggie's Avatar
it has to just be something simple I am missing
Old Jul 22, 2015 | 10:48 PM
nuggie's Avatar
found out that ih ad a vaccum line going to the barro sensor disconnected that and runs alot better and can almost get it to idle now tomorrow I am ganna test and see if the vaccum sensor is working anyone got a test sheet on that? Also where is the TPS on these I wanna check that to.
Old Jul 23, 2015 | 07:24 AM
naf's Avatar
naf
Best way to check proper operation is to connect a scanner to it while it runs, see what the ecm sees.
TPS is in the carb, 3 wire connector. Should read around 0.4 at idle and around 4.0 at WOT with the connector plugged in and top and middle wire backprobed. Again a scanner will show this. I use an autoxray 6000. Much less expensive today than when I bought mine.
Old Jul 23, 2015 | 08:49 AM
nuggie's Avatar
I do have the moats set up to tune the tpi ecu can I hook that up and will it show me?
Old Jul 23, 2015 | 10:14 AM
naf's Avatar
naf
Won't know until you try.
Old Jul 23, 2015 | 04:13 PM
nuggie's Avatar
I tested the tps and it showed good but how do I test the vaccum sensor it hold vaccum but I don't know what wire to prob to check for voltage or what I should see for voltage with volt meter
Old Jul 23, 2015 | 08:09 PM
nuggie's Avatar
okay so the vac sensor did have a 5v supply and when vaccum was applied it did put out voltage you to about 4.8. I also did remember that when we were messing with the starter we had to unplug the knock sensor so I plugged that back in there is also a smaller similar connection that I have no idea what it goes to (green single wire). tested it and same thing will start really easy won't idle and when given gas doesn't matter how much pedal will not wrap up. also anyone got info on how to use the moats reader to actively see the sensors?
Old Jul 25, 2015 | 09:12 AM
naf's Avatar
naf
provided the ignition system is good-meaning new cap/rotor/plugs/wires and sometimes distributor-it should be able to idle WITHOUT the ecm controlling anything. IOW a bad sensor somewhere is not preventing it from idling.
replace all of that ignition stuff with new and examine carefully the condition of your distributor if you don't go ahead and replace it while you're there.
if, after all of that's good and it still won't idle, time to open the carburetor.
Old Jul 25, 2015 | 02:08 PM
nuggie's Avatar
okay so went through the ignition system even took the ICM out and had it tested and it will almost idle but it did seem to be bein effected by the ecm because it would change rpm and sometimes shake and other times not but I got it to idle a bit so now I think I might be able to time it. I wonder if the base timing is set to advanced right now so when the ecu tries to advance it goes to much can't hear knocking but the friggen thing is so loud due to the exhaust being cut
Old Jul 25, 2015 | 03:47 PM
nuggie's Avatar
what do you have to diconnect to get a true base timing
Old Jul 26, 2015 | 04:35 PM
naf's Avatar
naf
disconnect the four wire connector to the distributor. should be laying in the harness a few inches from the dist base.
Old Jul 28, 2015 | 01:56 PM
nuggie's Avatar
almighty so I was working tiring to set the idle on her today and heard some valve rattle so I popped the valve covers off to find that one push rod was bent and another broken...
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
GVMV
Aug 16, 2015 08:01 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
