nozzle drip left venturi ccc-qjet
Old Nov 13, 2015 | 02:32 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Experiencing persistent nozzle drip only in the left venturi on ccc-qjet (two different ones). What I found was slightly bewildering. Will post pics later.
Hint: drip disappeared when vacuum line was removed and 50% dwell was obtained with idle mixture screws several more turns out but idle speed remained too high.
Old Nov 13, 2015 | 06:13 PM
Damon's Avatar
Re: nozzle drip left venturi ccc-qjet
Nozzle drip from the left side only with TWO different carbs? I think we can safely assume it's not a carb issue.
Old Nov 13, 2015 | 09:15 PM
naf's Avatar
naf
carb main body:
carb gaskets:
see the problem?
Old Nov 13, 2015 | 09:16 PM
naf's Avatar
naf
The one on the left is the one that fails.
Old Nov 14, 2015 | 08:50 AM
naf's Avatar
naf
The left gasket covers the lower idle air bypass feed from the main body. See how the circled part of the gasket is smaller. (gasket is upside down in the photo: right is left side)
Don't know which carb rebuild kit has this gasket in it. I've been using an assortment of rebuild kits I bought at close out off of Rock Auto several years ago. Had I noticed it would have been simple enough to modify the offending gasket upon install.
Someone should have told me to look for this....
Old Nov 15, 2015 | 10:26 AM
Damon's Avatar
You should look for that when you buy gaskets.
Wouldn't have thought that small difference would have mattered.
But I guess that's the difference between a CC and Non-CC QJet gasket, if I had to guess. Notice no hole for a vacuum-operated power piston on the right gasket either.
Old Nov 15, 2015 | 02:01 PM
naf's Avatar
naf
Yep. Not exactly feeling like mr. 'Attention to detail' for using two of these gaskets on different carbs but after sitting at the bench looking at one for about 30 minutes, it finally came to me.
Right gasket installed and the idle cleared up.
John1987formula
Apr 13, 2020 09:58 PM
Hotrodder
Nov 15, 2015 01:04 PM
spoazzy1
Nov 15, 2015 12:12 AM
theking11863
Nov 14, 2015 06:23 AM
1989CamaroIrocZ
Nov 13, 2015 09:43 PM
