ECM DELETE, VATS DELETE
Old Feb 25, 2017 | 09:38 PM
nollsracing's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 5.0 (305)
Hey I have a 1992 Camaro RS. It was a TBI car and it's now a Carburetor. I'm looking to delete the ECM and vats. If I do that will I lose my speedometer. If so how would I get it to work? And right now I have everything hooked up and I can't crank the car. im guessing it the vats. Can someone please help me. Thank you
Old Feb 26, 2017 | 10:20 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM DELETE, VATS DELETE
Tbi in that year uses a vss buffer, just leave it in place.
To bypass the vats jumper the starter enable relay.
The relays under the drivers side kick panel.
Connect the larger two gauge wires.
Old Feb 26, 2017 | 10:28 AM
Engine: 5.0 (305)
​​​​​​​thank you I will give this a shot cause in not even getting a click from the starter solenoid
Old Feb 26, 2017 | 10:34 AM
Engine: 5.0 (305)
I don't see that plug all I see is a relay connector with those wires
Old Feb 26, 2017 | 11:23 AM
Engine: Lb9
Transmission: M20
It might have a different looking connecter and be next to the fuse box.
Large yellow to large green wire to bypass.
Old Feb 26, 2017 | 11:28 AM
Engine: 5.0 (305)
Yes I found it and it turn the motor over thank you guys
