vats with a carb.
COTM Editor
Received 1,857 Likes
Car: '89 Firebird
Engine: 7.0L
Re: vats with a carb.
Yes, you will need to bypass VATS. Reason why is because the engine controller gives the PASSkey module permission to enable the start relay, but you won't be using the engine controller any more so the start relay is not going to operate.
https://www.thirdgen.org/forums/ltx-...ml#post5963351
The solution is quite simple. All you do is wire around the system. There are two methods you can choose from,
1. Let the key switch operate the start relay. In this method you jump terminals A3 and B1 at electrical connector to the PASSkey module. You can leave the connector disconnected or plug it back into the module, doesn't matter either way. The start relay still will be used but will be operated directly by the key switch.
2. Eliminate the start relay. In this method you unplug the start relay and jump the larger (12 gauge) wires at the start relay. The wire colors are the larger Yellow wire (not the smaller one), and the Green wire with Black stripe. Just toss the start relay because you won't need it any more.
Keep in mind that the starter will engage any time the key switch is in the crank position so don't do anything stupid with the engine moving or you'll mill the gear.
