Fuel tank question
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Fuel tank question
Are our fuel tanks a 2 piece design. I see they sell replacement them filled necks
When I turn mine sideways with fill neck facing down I get fuel dribbling out around where the fill neck meets the tank
Transmission: 4L80E/4L80E
Re: Fuel tank question
Not sure what you mean by "2 piece".
The filler neck is soldered to the main tank, and if it leaks there, it needs to be repaired or replaced.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Might take some research But there was a recall for this exact problem
MY fuel tank was replaced in the mid-nineties under warranty
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Rock Lobster lists replacement tanks with or without fill necks. Maybe this is what the OP is referring to?
https://www.rockauto.com/en/catalog/...fuel+tank,6268
Why they would offer a tank without a fill neck is puzzling.
I replaced my fuel tank a week or so after I drove it off the used car lot with a GM replacement because it leaked at the tank/fill neck joint when full.
