Mechanical fuel pump replacement question.
Old May 11, 2017 | 08:05 PM
siuol's Avatar
Car: 1987 Firebird Formula
Engine: Carbureted - 305
Hi, I am going to replace the original mechanical fuel pump on a 305 carburetor engine.
There are two fuel lines going to the pump from the tank, one larger, I assume its the fuel supply and a smaller one, which might be the return line. My question is: if I remove the rubber lines to replace them, will I get fuel flow from the tank. Is the tank higher or lower than these lines?
thanks in advance,
Louis
Old May 11, 2017 | 08:08 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Mechanical fuel pump replacement question.
you shouldnt get any flow.
Old May 11, 2017 | 09:02 PM
Take the gas cap off first.
Old May 11, 2017 | 09:18 PM
NoEmissions84TA's Avatar
Buy the Carter M6626 pump. Only about $20. It will be an upgrade.
Old May 12, 2017 | 01:13 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Don't buy a cheap Chinese fuel pump,...... Most cheap aftermarket pumps have a weak internal spring on the 'rod lever' that causes a "click" or "TICK" sound that sounds like an internal engine problem. When sitting in the car the sound seems to come from the tranny tunnel like a cracked flywheel or a bad rocker arm / lifter tick.
This pump had only a few hundred miles on it when it started Ticking. The TICK was worse at start-up but was always present. I thought the newly rebuilt engine had a major problem - but it was just a cheap pump. ( worked fine ) Re-set the rockers 3 times and then replaced the rollers with stock steel and even had the car on ramps ready to pull the tranny cause I figured it had to be a cracked flywheel. I got under the car on ramps after starting it up and realized that I could hear the TICK loud near the back driver tire ??? That's when I realized the TICK sound was traveling thru the fuel line............
Old May 12, 2017 | 07:53 AM
siuol's Avatar
Thanks guys, I have the carter pump on order.I am glad to see we are on the same boat on pumps.
Louis
Old May 12, 2017 | 10:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Had that same problem with a newly rebuilt engine with brand new fuel pump in the 80's (not in a 3rd gen, though). Sounded like a diesel.
on the 6626.
