Hoses for carburetor replacements
Old Aug 5, 2017 | 04:07 PM
Cameron Abeel's Avatar
Car: 1987 Firebird Trans Am
It's a E4ME carburetor. A 1987 trans am 305.
I just took apart my carburetor getting ready for a full rebuild. When I took it apart I realized all the hoses leading to the carb was mostly frayed and or broken. Partially my fault do to lack of experience and tools but a lot of it was there from last owner. Are there any sets for all the hoses. The fuel line is also bent to the point where it's flat and so is the other metal hose (not sure what it's called). Any help would be greatly appreciated espicially with guidance towards finding all the hoses and also a good rebuild kit.
Old Aug 5, 2017 | 08:18 PM
siuol's Avatar
Car: 1987 Firebird Formula
Engine: Carbureted - 305
Re: Hoses for carburetor replacements
HI Cameron, I replaced my fuel line from pump to carb with this kit. Its a flex line and works really nice. If you want to remove the old steel line, you have to cut it in several places to get it out from behind the water pump.
CRURF201012
Fuel Line Pump to Carburetor for Crusader GM V8 305 350 for Rochester
Fuel Line kit. Replaces the steel Fuel line from the Fuel pump to the carburetor on small block GM engines (305 350 Cubic Inch) also called (Model 220 and Model 270) that are equipped with the...
$83.99
Here is the link to the line.
http://bpi.ebasicpower.com/shop/inde...th=286_288_340
Louis
